Header Bolts Against Header Tubes
bostonbronconut
Question Asker
Wayland, MA
I'm replacing the passenger-side header gasket and it took me forever to get some of the dang hex bolts off of the header. As you can see from the photo I took (pass-side-old-header-hex-bolt), some of the bolts were right next to the tubes. I bought 12-point bolts to replace the hex bolts in hopes it would make installation easier but I ran into the same issue when trying to secure the header back on.
I've looked at other headers on Summit and Wild Horses and there looks to be significantly more space to get a wrench or socket on the bolts. The headers on my Bronco does not resemble any brands I've seen online thus far.
I'm sure I can just go back to using a hex bolt and taking 60 minutes to secure one bolt but I can't imagine this is pretty common, right? Thank you for your feedback.
EPB72
Pleasant Hill, CA
To me looks like toms long tubes ...Yep 6 point to get open end wrench on or message for clearance to use 12 point for box end of wrench,,,,maybe a small ball pin hammer with a second hammer to strike with that way you my be able to do in place... pull spark plugs where needed cover hole
Lawndart
I have Hooker headers and a few of the bolts are the same way. I have a open end 7/16" wrench with a standard angle open end and the other end is almost a 90 degree open angle. This is what I use to keep the bolts snug-ish.
EPB72
Pleasant Hill, CA
Hey lawn dart which hooker headers are they the mid length .if so do run a manuel trans concerned with clutch linkage interference
rmk57
Heat the tube up to red hot and clearance the tube with a ball peen hammer. It's not going to hurt anything. They also have header bolts that are allen-keyed.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I don't know if they are Tom's. The first two header tubes from the grill on my Bronco go over the third tube whereas Tom's go under.
Waverous
Aurora, CO
I've had luck installing headers with binding bolts by:
  1. identifying which bolts will bind
  2. Then finger start all the bolts just until threads start and can hold header weight
  3. Next, sequentially tighten binding bolts one turn at a time and walking the header to the head
  4. Finally, finish tightening the remaining bolts
So far, no problems - just a slow process.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
All signs are pointing toward the Scott Drake long tube headers.
That being said, a $20 ball peen hammer is cheaper than a new set of headers.
Pretty common with headers. I think my last set had 3/8" head for the bolts. Open end wrench was expected. If you have a nice high quality wrench the walls of the closed end might be thin enough to go on. I really don't see a 12-point working there. An allen head bolt could work better.
That is what you get when trying to get big tube diameters on a small block ford. The factory mustang headers have huge dents in the tubes so the workers can slap the exhaust on the heads really fast. Thus the performance headers that were a copy of the factory only without the dents, just a lot more work to install.
Lawndart
They are Hooker Competition headers. They seem mid-length as they are not short, however do not level out at the base either. I have an automatic C4, however the shift rod portion of the linkage was swapped from the outside to the inside of the shift lever at the tranny due to clearance issues. IIRC, the adjuster bolt would hit the header if in stock location (protruding outward vs inward).
ransil
I have a custom bent open end wrench for stuff like this. BFH and a vice to make it
englewoodcowboy
Lick Creek Restorations
I use the header bolts that BC sells for that reason. They work well and are easy to get a wrench on.
SevenT
Southern Colorado
Header bolts
bostonbronconut,
I am with Timmy390, I have used Stage 8 bolts for 20 years on my headers (93 Ranger with a 302 and my 70 Bronco). They have allen heads for when the bolt is close to the tube. Never leak, never loosen. Just bought some valve cover ones to stop that incessant leak when the valve cover bolts loosen up from vibration.
v/r,
SevenT
Timmy390
Conway, AR
I mentioned the Stage 8's because they were allen head. I didn't mean to indicate they were necessary for proper sealing.
You can get allen head header bolts from a few sources. I've seen stainless ones on Amazon and eBay.
I use Stage 8's because no matter what I did my header bolts kept backing out. I installed the stage 8's and haven't had an issue in 2 plus years.
Tim
nvrstuk
PNW
Crows foot socket.
When it comes to header bolts, I use everything. End wrenches, sockets, and crows foot sockets. Whatever it takes to get the bolt tight.
That's exactly why so many have gasket failures with headers. They're not getting the bolts tight to begin with.
Also, locking devices like "stage Eight" aren't necessary. If you get the bolt tight, it's not coming out. The stage eight system will only keep loose bolts from falling out. By that time, the gasket is already leaking.
Those bolts have to start out tight to stay tight.
Disagree... partially. :) I do think some flanges don't seal as well as others even when checked for flatness.
Header bolts against "dead soft" header gaskets sometimes will back out...
About 4 sets of headers ago on my Bronco, I had all the 3/8" hex head bolts as tight as they would get- over and over. Within 100 miles they would back out... fought this for a YEAR. Bought a set of Stage 8 fasteners with the same gaskets, 12 years later I sold the engine and headers w/o an issue since the Stage 8's.
Most of the time if you have header bolts that back out on there own it is due to improper exhaust support down by the collector. Allows the collector to bounce up and down to the engine and that is what works the bolts loose. Look at a V8 Explorer (or even a stock 5.0 mustang) with factory headers. There is a support for the exhaust by the transmission crossmember, the transmission holds the exhaust before passing it off to frame (body) hangers.
blubuckaroo
Grease Monkey
Ridgefield WA
I have never used a header bolt lock, and have never had a header bolt loosening issue. In my experience, if you get the bolts torqued correctly then retorque correctly after a few runs, you're good.
I think the ones with problems aren't really getting them torqued from the start.
It's tough. End wrenches, sockets, and crows foot sockets are usually needed to get it right, and that's too much work for some.
I've had quite a few vehicles with header, and no gasket/bolt issues. I only use standard header bolts, and plain old white Hooker gaskets.
