So the Bronco Hut headers have been installed for less than 2 weeks. I continued to heat cycle and retorque the bolts, chasing a very small exhaust leak on the drivers side. I used the Edelbrock gaskets supplied with the headers. The bolts definitely stayed tight, and just when I was ready to pull the drivers side to check the surface again (flat and true when installed), I get a nasty leak on the passenger side. Much worse, it would appear that the gasket has blown out. The drivers side couldn't be located at idle, only really happened under power. The passenger side is obviously coming from the rear ports at idle. I'll be pulling both to check things over, as no amount of tightening seems to help. I've checked all the clearance issues indicated in other threads, and I'm not hitting anywhere. I planned to get some Remflex gaskets and give that a shot, but I can't find any good info/part numbers for the GT40P heads. Anyone know if the basic Windsor 289-351 gasket will work with the Bronco Hut headers and 2000 Explorer GT40P heads? Anyone happen to have used them and have a part #?
