Headers on 351w.
lewain
I am thinking about putting some headers on on 1976 Bronco with a 351w, c4 automatic transmission.
Also, want them to turn out behind rear tires. Future will probably add an up graded fuel tank.
What is recommended and what should be addressed. ie,,,,starter clearance and over heating, brake lines, or any other clearance issues should I look at.
Also, what mufflers are easiest to configure? I have a set of cherry bombs on now with true dual exhaust
Or should I just stick with stock manifold with new system? Long tube or Short tube?
Jakedog
I ran a 351w in the 90's. I didn't have any clearance issues.
My exhaust was a single 3" pipe before the passenger right rear.
It was a 2 in 1 out flowmaster.
Amazing sound!
PNW
I'm into performance and practicality... sometimes they don't mix well :) but hey- it's all fun!
Headers will introduce more heat into your floors and firewall. Probably the biggest down side of them over the stock cast iron flow reducing manifolds.
I fought heat for decades along with most everyone else who's installed headers. There are hundreds of posts here on ways to help address heat. Floor liner coatings, insulation, carpet, etc, etc, etc.
At one time or another I've tried most of them. Metal heat shields held off the body 1/2" from half way up the firewall to the back of the muffler work the best- bar none. Look at OE, they all use shields on mufflers.
Anyway- what's your goal for using headers?
Cherry bombs were the bomb of the '70's but they create a lot of back pressure and are obnoxious. There are lots of free flowing somewhat quiet or LOUD muffler choices. IF you drive this a LOT then my .02 is this, do NOT install flowmasters as the drone will drive you insane. It is obnoxious as heck. For a 5 min drive to the mall you can handle it. If you really drive your Bronco for an hour at a time at 60 mph you will wish you'd chosen something else.
I run big cams on big cubes and like a true dual exhaust. I can not fit a crossover in otherwise I would-literally no room and my exhaust is outside the frame anyway so it's really not worth it. I am fussy about exhaust and have lowered my floors, moved body mounts, etc so I can run free flowing mufflers and they are 50 % longer than typical UltraFlows- at 20" body length to help quiet the HP.
Brake lines and fuel lines MUST be rerouted to avoid issues. Go to a good custom exhaust shop and be there when they install it.
Glass Pony
Sussex County Delaware
I'm running long tube headers with the 351W, C-4, turbo mufflers, 2-1/4" dual exhaust exiting behind the rear tires.
The things I have and don't have help, like 2" body lift helps with clearance, not having an auxiliary tank helps.
I also run the 23 Gallon NWMP tank in the rear but the folks at the muffler shop was able to get around it.
mustanggarage
I highly recommend James Duffs ceramic coated long tube headers. I don't know what I did that has made the difference, but I used there ceramic coated headers with there true dual exhaust and magnaflow mufflers. I have a 2 inch body lift to clear things under the hood, I used bedliner under the body, and lizard skin heat shield, sound deadening and raptor liner on the inside of the bronco, I do not have carpet, just some floor mats but I get very little heat through the floor. I can comfortable drive barefoot if I want to. I have a bluprint engines 408 with sniper fuel injection. I suppose all the things together have made the difference, but in other vehicles I have built I can say that the ceramic coated headers do a lot to reduce heat under hood.
BroncoJimbo
Long-term owner
North GA
I have a 351W with old James Duff chrome headers that I've run for 22 years. I use a GR starter but didn't have any issues with the stock style. I run two Flowmasters with pipes exiting at the rear quarters. I don't have a problem with heat from the floor even though there is just Durabak with no carpet. As far as a drone with the Flows, not nearly as bad as my Mustang was with Walker turbos. No body lift, just the upgraded body mounts which is +3/4" IIRC. I love the way my Bronco sounds.
lewain
lewain
nvrstuk, you certainly make good points.
My mufflers now are actually “glass packs”.
I think that I am going to stick with true duels with new pipes and maybe some mild Flowmasters.
I recently put new high back bucket seats in. While waiting for delivery I removed the old seats.
New seats came in without the mounting brackets. So, while waiting on the brackets I thought why not do new carpet.
With carpet out I decided why not insulate. So, pulled out panels and headliner and insulated everything.
Made my Vintage A/C cool better even here in central Florida. with100 degree days.
PNW
DynoMasters or UltraFlows ... anything but... and again just my .02 and anybody I've ever travelled with for more than an hour at cruising speed (like 35mph or more) but the drone on Flowmasters will drive ya nuts.
Chevelle's and Fairlanes can deal with the drone because you're literally 15' away from the tailpipes... lol
mustanggarage
To add to my earlier post. James duff offers there true dual exhaust with several muffler choices and they fit well. I really can’t recommend them enough they are the best name in bronco exhaust
bronco italiano
If you can source Doug Thorley headers I would go that way for two main reasons:
1- Probably best EB long tube every made quality wise
2- They carry the CARB compliant tag just in case smog becomes an issue
Regarding heat, and this is gonna sound ridiculous.
-Make sure the header is thermal barrier coated inside and out. Many headers are only outside coated.
-Have your entire exhaust inside/out thermal barrier coated, use v-band clamps at the muffler inlet/outlet. That was one of the best steps I took to get heat away from the engine.
-All the other items nvrstk stated are great additions
BroncoJimbo
Long-term owner
North GA
It's odd the James Duff listing omits 76-77 Broncos. I was checking since my old Duff's headers are getting a little crusty.
