Heater Hose Routing Solution
Bronco-Brian
Lake Oswego, OR
I've been unhappy for years running bulk heater hose to the heater core at the firewall and dealing with sloppy hose routing. Finally found a clean solution I thought I'd share with others. I spent 15 minutes with the O'Reilly's auto parts kid and found a molded hose p/n that fits the bill nicely. Checkout Gates 18836 molded hose.
You will need to cut off the last 3" of the double 90 deg bend end and I route that side near the valve cover. The 90 degree bend at the heater core is perfect for early Bronco inner fender clearance. See pics below. The inboard hose runs to the heater valve (perfect length), and the other hose uses a 5/8" barbed union. From the heater valve and the union to the intake and water pump, I just use bulk 5/8". Way cleaner install than I've ever had in the past.
Howard2x4x4
Great tip, thanks a bunch! Howard in beautiful West Michigan
ngsd
Looks good. I did something similar except used a hard line along the manifold as the connector. I think it was from a 70 Mustang Mach 1.
cscotted
Nice tip on heater hose pn#. Thanks for sharing.
Cool clamps also. Until its time to remove one. Lol
Ratclge
You can also go to Napa and look in their hose books,they can get any length of 90s and straight length u want.
jamesroney
Fremont, CA
Bronco-Brian: To add to your thread, the Dayco 80408 is my "go to" universal heater hose for the suction side. 69 inches long with a molded 90 on one end.
I just ordered the Gates 18836 for the valve side. THANKS.
68Broncoz
This is a great and timely post as I am just getting ready to put my heater back in the bronco. Does this same set up work for the explorer serpentine swap with the reverse rotation water pump?
Chris
BPerry
Two very clean setups! Now would someone please post some filthy engine compartment pic's so I don't feel so ashamed....
I would think so.
The port outlet/inlet fittings on the Exploder pump are in virtually the same locations and orientations. Probably close enough... So in that regard it can work.
Your alternator kind of dictates that both hoses run over the top of the engine anyway, vs going around the side like originally on the Bronco.
The flow direction of the pump should not matter to the hoses either I don't think. Unless someone can say that the flow from the heater hose ports is reversed as well? And that the top hose connected to the intake manifold is now flowing in to the engine rather than out of?
If it does make a difference, then in theory you would just put the valve in the other hose and it should still work. If you do have to swap hoses, I don't think you'd even need a valve with the different flow direction. The same direction should work.
Wonder who's experimented with this? On mine I have the full Explorer setup with the hard tubing across the engine, connected to a non-stock heater core with A/C. So not the same apples-to-apples comparison.
