brad smith
I’m full of questions. And I know this has been a topic before. But doesn’t anyone have a diagram of the heater hoses with the control valve showing in it? Thanks
Not a diagram. Hope it helps.
Easy peasy…just like it was designed for it.I’m full of questions. And I know this has been a topic before. But doesn’t anyone have a diagram of the heater hoses with the control valve showing in it? Thanks
What hose goes where into the coreEasy peasy…just like it was designed for it.
289 engine will be routing the same way I assume? Thank you. Mine is a 302
It doesn't matter which direction the coolant flows through the heater core. It's actually good to reverse it occasionally to remove sediment deposits.What hose goes where into the core
Yup. Note that the heater core flow is reversed from V8 to I6 in the pic by @Oldtimer.It doesn't matter which direction the coolant flows through the heater core. It's actually good to reverse it occasionally to remove sediment deposits.
(click this text)
Did they have mounting parts thst the hoses ran through or were they just laying up on the intake area or fender well?No, that sounds perfectly legitimate and even more logical than the part about adding heat.
I never followed through with my thinking, but I always wondered about it because, exhaust heat or not, it always took all the Broncos I knew a long time to warm up enough to do any good.
Although, a few years down the road, when all of the exhaust riser tubes have rusted out or been removed, maybe that heater hose actually did help add some heat.
Sort of a backup, so to speak.![]()
2nd owner.And you're an "almost" original owner if I remember. You think it was factory, or added?
I don't remember, but was that your dad that did the engine swap?
I have another question. I am replacing the elbow fitting going in to intake. I noticed when I pulled mine out it doesn’t have the extra stem past the thread. Does it need this stem or can it just be the threaded part and no stem. All I’ve seen pics of is mainly the stem type. It’s a 3/8 pipe with a 5/8 barb hose Thank youThe upper hose is attached to the tubing elbow right on top of the intake. So it’s pretty solid there.
Then it lays in a curved tray that holds it right up against the choke housing. Not far behind that is the heater control valve, floating there on the cable.
So while it’s not really considered to have mounting brackets on the intake manifold, it’s pretty well supported until it turns down and over to the heater core.
The lower hose just floats around. Many of us have added clamps, or clips, or zip ties, or whatever, to support that hose.
Nothing from the factory that I remember.
Thank youI’m not 100% certain on the purpose of the stem, or siphon tube, or whatever that appendage would be called. But I believe that it either enhances flow, or more likely that it takes its water from lower in the area, closer to the, bottom surface of the manifold, probably to get hotter coolant flowing through.
Used to think it was there to enhance flow, but it’s probably just to ensure that the hottest coolant goes to the heater.
Maybe it’s also less disruptive to flow through the thermostat.
Personally, I’ve always used the appropriate fitting.
