cgbexec
I am doing a complete frame off on my 1976 EB. I have ordered tons of parts and in a month or so will begin assembly (when the body is back from the body shop). I went with a Centek harness.
1) I ordered an HEI distributor (JBG). This distributor has a one wire hook up. Does the wireing harness cover this install or am I going to have to figure it out? Any pointers here? I need plug wires also. How do I order wires when the motor never came with an HEI distributor? Is there another Ford Application that I could use to order wires?
2) I also ordered the small case hi torque starter (JBG). This starter has a solenoid on the side. Is this the starter solenoid that replaces the seperately mounted one or is that solenoid mearly for engaging the Bendix? It has a one wire hook up on this solenoid. How do I wire this?
3) I ordered an internally regulated alternator (170 AMPs) from JBG. This is a one wire hook up. Any pointers on how to hook this up?
Sorry for all of the questions, but none of these items came with directions on how to install in an EB.
Thanks in advance.
Chris B.
Thanks in advance.
Chris B.
