Help!!! Engine Not Running Right!!!
broncoitis
Ok, good thing is that the engine is running! However, something is off.
If I open up the throttle body / give it gas it seems like it wants to stall! I think if I open it up too fast it would stall. I basically seems to bog down. What do you guys think?
Could it be a Vacuum leak?
Timing off? Should I advance or Retard?
Just trying to cut to the chase. So far all the other problems have been solved so hopefully you guys can steer me in the right direction on this one. ;D
Rob
Viperwolf1
electron whisperer
Bust out the timing light. Check for codes. Check fuel pressure.
jperry1290
Not sure if its helps, but I checked fuel pressure, changed plugs, replaced all vacuum hoses only to find the vac advance was bad
broncoitis
broncoitis
Fuel pressure is in the 35 - 40 psi range! Should be ok on that front.
Gonna check the timing and see where that takes me.
Thanks guys!
Anyone know how to use the spout connector to adjust the timing with the RJM harness?
Viperwolf1
electron whisperer
Unplug the SPOUT connector to check initial timing. Plug it back in afterwards.
Fuel pressure is good.
broncoitis
broncoitis
Viper,
How do you use the spout connector? I know where it is but the directions are very vague about how to use it to set the timing initially. Thanks to you and anyone else that may be able to explain how to use it.
Rob
tasker
all knowing of nothing
NH
it should unplug from the harness, set your timing and then plug it back in....it's not a tool
Viperwolf1
electron whisperer
The SPOUT connection allows the computer to control the timing. The computer adds timing based on rpm, load, temp, etc. By unplugging it you can set the base timing with a timing light. It's the single wire weatherpak connector near the distributor. Set it to 10 BTDC then plug the SPOUT connector back in once done.
broncoitis
broncoitis
Alrighty then! ;D I will give that a shot and see where that take me.
One thing that I will mention and I don't know if it will effect the base timing or not but I have 1.7 ratio rockers vs. 1.6! Not a big difference but different nonetheless.
Thanks guys.
Viperwolf1
electron whisperer
Rocker ratio makes no difference in procedure of setting the base timing. The motor may favor a slightly different base timing though. I'd set it at 10 BTDC for now. You can play with a little advance/retard later to see what it likes.
broncoitis
broncoitis
Come to think of it, my VSS is still not connected! What effect if any would that have on the engine at idle???
Viperwolf1
electron whisperer
No effect if the vehicle isn't moving.
Can you give us a rundown of what parts you used? Things like MAF, ECM, harness, injectors, etc.
Have a chance to look at the codes yet?
broncoitis
broncoitis
RJM Harness, Bosch O2 sensors, Napa 91 mustang Barometric Press Sensor, MAF sensor off a taurus, 91 Mustang A9P computer, 91 Mustang ACT, Summit Racing Dizzy, 91 Mustang Coil, 91 Mustang IAB, Autozone TPS, Explorer Injectors, etc..... not sure what else!
Can you adjust the timing off the balancer with the truck not running or does it have to be done with the engine running?
Also, is there a learning curve for the computer with the engine?
Engine is running hot and blew off a radiator hose today and had to clean up that MESS! :( That really sucked to put it lightly.
Currently there is no Shroud on it but there will be by the end of the week! Any suggestions on a shroud? Running a 1 inch body lift with the explorer stock fan setup. Thanks for the help everyone.
Viperwolf1
electron whisperer
Tell me more about the taurus MAF sensor. It could be causing the engine to run lean and get hot. Might try just unplugging it to see how it runs.
Engine needs to run to check timing.
There is a minor trim learning curve in the computer but it should run fine without learning.
As I recall the stock shroud fit pretty well with the explorer fan.
broncoitis
broncoitis
Got it at a junkyard! Taurus I don't believe was ever offered with the 5.0. Although it does fit the Mustang MAF housing exactly the same and has the same plug as the Mustang sensor as well.
Unfortunately the mustang one that I bought was cracked. :(
Viperwolf1
electron whisperer
98% chance that is your problem. Never swap sensor and housings especially if the sensor isn't the right one to begin with. What is the part number on the sensor?
broncoitis
broncoitis
%)You think that could make it run so hot like that?
I mean it popped the hose off the crossover pipe but I will remedy that from ever happening again tomorrow with a small bead around the edge!
I wish that I had the truck close by because I would get you the number off the Sensor but it will have to wait till tomorrow. The sensor and housing looked exactly the same to the Mustang.
Gonna see if the local auto parts stores have a replacement tomorrow to see what happens. Never really even gave the sensor a thought.
Viperwolf1
electron whisperer
It looks like the taurus sho may have used the same sensor as the '91-'93 mustang. You would have to check the part number though. F1ZF-12B579-AA
broncoitis
broncoitis
Ok! I am gonna check the part number first thing tomorrow. Boy I hope it is a different number. :eek:
broncoitis
broncoitis
That is the sensor that I have! I don't think it is the sensor. Especially considering that I bought a new MAF from ford today and it still ran the same. Think it is a timing issue going back to TDC! I have to figure out where that is on this damper with the pointer on the other side!
I just thought of a way doing it with the new pointer located in the 10 o'clock position. If this doesn't work, I am gonna throw a match in the tank! ;D
