Hey guys,
I have a 75 bronco that I have mostly restored. Over the past year I have been getting a terrible noise with acceleration especially right around 40 mph. I have had the transmission rebuilt ( for a different reason but no effect on the noise), the transfer case ( figured while I was at it). The output shaft on the transfer case was bad and it quieted down some but still lots of noise. Here is actually a link to a video of the noise. Notice the increase in ?metal noise? around 40mph.
https://www.youtube.com/watch?v=Rmwl-cln5zg
I have had drive shafts checked, new U joints, etc.... No change. My transmission guy, who is very good, thinks it is the rear end. We have rebuilt everything else and the noise did start about 6 months after having the rear/front gears changed to 4:11's ( he didnt do it someone else did). He thinks it may have been shimmed incorrectly. But I have been super busy therefore put it off and only driving my Bronco very little.
Fast forward to today, I was chasing a leaking brake line and stumbled upon a different type leak on the right rear wheel. It appears that the axle seal may be bad as everything ( including the brakeshoes) were covered in a thin brownish grease. I do not think I have every replaced them,so I remove everything ( luckily the axle came out very easily. The seal appeared intact, bearing looked OK, I didnt note any groove, the vent is not clogged BUT.....I found this in the gunk in the axle housing. I looked over the bearing closely and it does not appear to be from it as it is still intact. My plan is new bearings/seals/axles and brakes but looking at these metal pieces and considering the noise, would you open the rear end? I have never worked on one so am a bit leery. I would certainly appreciate all comments, input, advice, etc.. I also would appreciate any advice for upgrades to the axles, axle seals etc...
And thank you in advance.
G
G
