Help Identifying a wire
wvumurray
Total Newb here. Bought a 77 bronco and not sure what this wire is. It is to the left of the distributor on top of the engine connected by a rubber boot. The other end either got disconnected from somehwere or was not connected when I bought it. Car ran when I bought it but after being shipped it wouldn't start. Here is a pic. It is the red one.
nate213
West jordan, Utah
water temperature sender. but the temp sender is usually on the thermostat housing. there should be a hose that connects from there to the water pump.
SHX669
That's the common/normal location for the temp sender unit on aftermarket intake manifolds.
savage
Bronco Nut
Renton
Usually their is a fitting for the heater hose to connected to . It looks like they used it for the temp sender. The sender is usually on the other side of the distributor.
W
wvumurray
Thanks guys. That makes sense. The heater has been removed as this was a Florida bronco so heater hose not being hooked up makes a lot of sense. Thanks again.
SHX669
Guess I need to clean my glasses or flip my Smart Phone around - LOL - nice clean engine compartment by the way.
Steve83
That SHOULD have nothing to do with starting.
But what exactly do you mean by "it wouldn't start"? The key doesn't fit the lock cylinder? The key doesn't turn? It turns with no resistance? It turns normally, but nothing happens and the headlights don't come on? The headlights work, but no gauges? The gauges power up, but the starter doesn't spin? ...
You get the idea. "Won't start" is very vague because people use it to mean LOTS of things. Be specific.
jckkys
The engine was the victim of a real bubba PO. The heater hose elbow hole in the intake has a reducer to accept the coolant temperature sending unit. I wonder what is screwed into the correct hole on the driver side? The temperature gauge wire should come down the driver side of the carburetor with the oil pressure sending unit wire.
Is the Duraspark ignition still there? The '77s had the large diameter distributor cap to keep the higher voltage spark from cross-firing with the higher voltage. The thermostat housing is odd looking too.
savage
Bronco Nut
Renton
The thermostat housing looks like a 90* MR gasket, and the cap, looks like what I had on my 74 bronco, I think some came with the smaller cap. Which engine does your 77 bronco have? 351 or 302,or some thing else, can you take a pic of the hole engine from the top to see if your missing anything , some pics like these two would help. mine is a 74 but has been upgraded with the blue ignition box and harness and cap and rotor that came on the 77 .You said it wouldn't start, what does it do.
