GubNi
I'm trying to gather up all the parts I might need before I get started on my project. The plan is to build the ultimate EB. I want something that I can take on a road trip or the roughest trail around. I want it all! Here's a list of somethings that I know of. Help me figure out what else needs to be on the list. If you have an opinion of what I should add or take off, lets here it. Items with the "" are things I already have. Other items I still need to get. If you have those parts please let me know.
Dana 60 front
1. electric locker
2. 5.13 gears
3. bearings
4. seals
5. 35 spline stubs
6. 35 spline lockouts
7. spare shafts
8. spare hub
9. Chevy TRE steering
10. F150 P/S box
11. extended heimed radius arms
12. drop pitman arm
Dana 60 rear
1. electric locker
2. 5.13 gears
3. bearings?
4. seals?
5. 35 spline shafts
6. disc brake conversion
351W engine
1. 1970 short block
2. 1970 heads
3. head work
4. new cam (which one?)
5. gasket set
6. assembly
7. 351 mustang intakes
8. EFI harness and ECM
9. mass air meter
10. serpentine belt system
11. Saginaw conversion
12. 3G alternator
13. Dual batteries
14. Headers
trans-tcase
1. AOD with low gearing
2. AOD to D20 adaptor
3. D20
4. D20 output upgrade
5. D20 J twin stick kit
6. AOD shifter
Body
1. 1968 body
2. soft top
3. A/C
4. front seats
5. console
6. roll bar
7. winch bumper
8. Warn 9500
9. Gas tanks – efi?
10. herculiner
11. aux lights
12. hydraboost
13. big radiator
14. electric fan
15. marine? CB
16. marine CD player
17. grant steering wheel
18. 5 point seats and belts
suspension
1. 5.5” cage coils
2. 7* bushings
3. adjustable tracbar
4. rear shackle flip
5. driveshafts
6. shocks
7. 3" body lift
tires – wheels
1. 38” TSLs
2. 16x10 rims
3. spare
4. stauns
Dana 60 front
1. electric locker
2. 5.13 gears
3. bearings
4. seals
5. 35 spline stubs
7. spare shafts
8. spare hub
10. F150 P/S box
12. drop pitman arm
Dana 60 rear
1. electric locker
2. 5.13 gears
3. bearings?
4. seals?
5. 35 spline shafts
351W engine
1. 1970 short block
2. 1970 heads
3. head work
5. gasket set
6. assembly
9. mass air meter
12. 3G alternator
13. Dual batteries
14. Headers
trans-tcase
3. D20
6. AOD shifter
Body
1. 1968 body
2. soft top
3. A/C
4. front seats
5. console
6. roll bar
7. winch bumper
8. Warn 9500
9. Gas tanks – efi?
10. herculiner
11. aux lights
12. hydraboost
13. big radiator
14. electric fan
15. marine? CB
suspension
1. 5.5” cage coils
2. 7* bushings
5. driveshafts
6. shocks
7. 3" body lift
tires – wheels
1. 38” TSLs
2. 16x10 rims
3. spare
4. stauns
