Help me plan my build order...Build Thread!
N
Nickm1024cobra
Chicago Burbs
Holy cow!! This is the quickest build I have ever seen....
LOL. Still have a long way to go. Got the body undercoated and all mounted up. 2" body lift. I really don't like how far forward the rear tires are. I am going to be adding fender flares so hopefully I can get it a little better centered up.
Cage I am told is a Kentrol cage. Bought it in the classifieds. Fit my Kentrol tub so who knows.
This weekend I hope to get the hydroboost mounted to the firewall, pedal box in, and column installed. Maybe lay out some wiring if time allows.
Mtgrizzlymn
Looking great! How much room do you have for front driveshaft? Looks very tight by the tc and cross member
N
Nickm1024cobra
Chicago Burbs
I'll have to look when I get back in town. In one of the original pictures I didn't have it clocked correctly. When bolting it back up I looked at how I could clock it and I don't think there is another option.
I think it will be fine. Haven't read any issues with others who have done the mod.
N
Nickm1024cobra
Chicago Burbs
Work and family holiday stuff has been taking some time, but I'm still making a little progress.
Got my IDIDIT column bolted in and lower steering shaft mocked up.
With the column bolted to the under dash support it was not centered in the hole of the dash. Riding way up high. Not sure if this is where the stock column sits or what the difference is. Put a stack of washers to drop the height. Dont love it and might get some aluminum spacers made. Bolted it to the firewall with the original clamp support and it feels sturdy.
Moved over to the power steering and got the hydroboost unit installed and master mocked up with lines. Still need to bench bleed the master, but waiting on a couple parts from WH that didn't show up.
Had a local shop make the high pressure lines and got the return lines plumbed. Used the Explorer pump fitting from WH.
Remounted the reservoir a little lower and drilled/tapped for the coil as well. Once I get a hood I will see if this is low enough. Getting a raised cowl hood so we will see.
Last item I tackled was the shift linkage for the 4r70w. I used the Lokar 1808 setup. Tough part of the adjustment is the throw from park to reverse has much more travel than all other gears. I think I have it adjusted about as good as it is going to get. Lots of trial and error and different positioning.
Today I got the alternator on, distributor stabbed in, starter on, and tightened all the brake and fuel lines. Got the proper fittings from sweet performance to run the trans cooler lines from the 4r70w.
If you see something that looks funky let me know. This week I hope to have the mechanicals all in place so I can start laying out the wiring.
Cheers
N
Nickm1024cobra
Chicago Burbs
If anyone is still following.....
Yesterday she came alive. No joke, first time I've had one fire on the first crank. Must be getting better with age. ;)
Today she moved under her own power. Hydroboost, steering, all working well.
I didn't expect to send it to paint till may, but my painter called with an opening. I feel good about where it is at mechanically. I know the motor/trans/shift control, power steering, hydroboost all relatively happy. Leaves for paint in 2 weeks. Need to pick a color.
Oh, and disregard the crooked radiator that doesn't fit. LOL. had to buy a cheapo at auto zone since mine didn't show up in time. :)
carhauler
Harford Co. MD
Sweet Jesus man!! Do you have a day Job??!!?? I have never seen a build go so fast!! Looks great too. What did you figure out for the rear axle centering issue? I see that on a lot of glass body EB's it seems.
...and that cobra......:eek::eek::eek:
N
Nickm1024cobra
Chicago Burbs
LOL. Shockingly I work 50+ hours a week. But, when I start wrenching on a project I don't stop. I think for every hour I spend in the garage I probably research 3+ hours prior to each task. This way I don't take things apart left and right. Learned that with the Cobra. Forum here is a wealth of knowledge with the search feature. Realize though that I have it wired just enough to start and run. Once back from paint all the fun stuff. Dash, lights, interior, etc. But....I do like to build fast.
As for the rear axle being centered, not quite sure what you mean? Body seems to be centered on the frame, and axle stock to the original frame. You mind explaining? Sparking my interest.
Monster Mike
We make a billet aluminum column mount for flaming river that spaces it down to the proper height. Not sure if it will work with the ididit but feel free to give us a call and we can take some measurements for ya.
Build looks great, loving the suspension ;D
N
Nickm1024cobra
Chicago Burbs
Yeah those duff guys are alright. :)
Ill call you about the column. Glad to hear it wasn't a one off issue.
N
Nickm1024cobra
Chicago Burbs
This is what I was referring to. Just wondered what you figured out. No criticism, just pure jealousy!
Got ya.
I really don't want to cut the body forward of the tire. Just don't think it will look right. So...I'm going to wait and possibly repin the leaf springs or move the axle mount. Still debating fender flares. They are molded into the body as you can see, but I really like the black accent gorilla flares.
N
Nickm1024cobra
Chicago Burbs
I dropped it off to the painter yesterday. Hope to have it back in a couple months. Then, interior, finish wiring, bumpers, lights, top, heater, and all the rest....
Still hoping to be done for summer, funds allowing. Ill check back in when i get it back. Thanks for all the help thus far.
N
Nickm1024cobra
Chicago Burbs
Got Paint....These are right out of the gun. No cut and buff yet. Should have it back next week to start assembling. Hope you guys like it. Goal is still to be done by April/May.
N
Nickm1024cobra
Chicago Burbs
I brought it home from paint last weekend. Needs a little more wet sanding in some spots. Got the interior sprayed with Raptor liner. Next up, dash, windshield, cage, and top.
N
Nickm1024cobra
Chicago Burbs
Top is on. Will need some adjusting, but the initial fit is pretty good.
Windshield is in. Install video on WH website was very helpful.
Now on to more wiring... Thanks for the kind words. Always need some motivation to keep going ;)
N
Nickm1024cobra
Chicago Burbs
I got the interior in and the cage bolted back in. Next week my bumpers will be back from powder coat and I am considering installing gorilla flares. I ordered them to see how they would fit with the molded in flares already in the body. We will see what they look like before I commit.
Got my dash installed with speedhut gauges. Once I verify everything works I will wrap it with harness tape and make it all pretty.
She went around the block today for the first time and shifted right into 2nd. First time the 4r70w shifted. (Just crawled around driveway before). Another couple weeks and I should be there. Oh....and the oil pan leaks. First time I didn't use a feel-pro one piece...:mad:
