Help me read these plugs
norm02
I checked the plugs today on my freshly rebuilt 170ci and I wanted to show you all the pictures to get some opinions. I've put less than 100 miles on the motor since the short block and head were rebuilt but I only recently had a friend of mine dial in the tune. Before we dialed it in, I put approximately 60 miles on what seemed to be a decent temporary set up.
My friend is very knowledgable about these motors. In fact, he has a '64 Mustang with the same engine in it and he is a member of this forum. That being said, he fine tuned the motor using a very reliable vacuum gauge and an old school vehicle analyzer. He had it idling great and running strong in no time.
The motor built ~15hg of vacuum and we set the timing and air/fuel ratio. It ran great on the new found setting until the float in my carb started to stick and cause it to not idle. I worked on the carb today and now the float no longer sticks and it idles but the idle is pretty rough. It's perfectly smooth when accelerating.
I'm trying to figure out what else could be causing the rough idle so any ideas would be appreciated. Attached are pictures of the plugs that I pulled out tonight. Please let me know how these plugs look and please keep in mind that less than 20 miles have been put on them since the tune was dialed in yesterday. Thanks!
Rustytruck
Looks like too much choke or choke on too long. Engine could have too cold a thermostat or your not using heated air on start up. What rpm is your high idle when cold. Are you using autolite or motorcraft plugs?
rmk57
If all six plugs look like that your in good shape. That long log intake manifold is hard to get even fuel distribution on all cylinders.
Not sure about your rough idle.
Eoth
The plug looks ok to me. Keep in mind that you have made a good number of changes over a short period of time to get a good "read". The most important thing is that there is no signs of overheating.
As for rough idle... Could be a number of things but it isn't the plugs fault. Basic facts says that it ran good before the sticking float and after it didn't... Not knowing your carb, I would guess that you introduced debris into your idle jet OR your carb was tuned with the obstruction and your fiddling with your float dislodged it. You might want to re-tune it again before changing anything...
Good luck, these things can be maddening.
ledslinger29
I'd second the last post. adding that the timing may need to be reset if something major changed about the carb.
DaveLev
If your friend who knows motors knows his/her stuff, I'm sure they did this already: Be sure to plug the dizzy vacuum port when checking timing. Easiest to disconnect on the carb side, as that one on the dizzy strips easy. Your Hg (vacuum) reading and the plug look good to me. The carb is two bolts and a throttle linkeage. Easy to pull that off put on bench and gumout the innards.
norm02
norm02
That's what we did and I was happy with the vacuum. Cleaned out the carb yesterday and it idles but it was still rougher than I had hoped it would. I'm going to drive it some more and see if it cleans itself out any. Will make some minor adjustments as I go as well.
DaveLev
Do a compression test after 50 miles. Retorque those head bolts - with a high quality torque wrench (snap on, digital, etc.).
Pa PITT
Stephenville TEXAS
.. OK I'm about the oldest fart on here . & I HAD A parts store back in 1967 .until 1995 So I've seem a lot of those issues .
.. I'm going to say one motor just breaks in faster than the next motor. Go Drive it like you just stole it. Or DRIVE IT ABOUT 50 miles down the road about In a round trip .. Get it good & Hot for an extended period time . Of COURSE DON'T BURN IT UP. BUT What plugs are in it. Put in some Champions F14Y OLD NUMBER sorry I don't know the new number . Or cross RF14Y to AUTOLITE or Motorcraft .. Don't use any other plugs .
I think your ok I think you just need a few more miles on it. & I'm not above retorting the head bolts .. That used to be a 500 mile redo.
... I guess you do have a big Clean air filter on it . Not a dirty 2 inch filter over the carb.
