Help me read this vacuum gauge?
wegngis
Oregon
Hey guys, I threw a vacuum gauge on manifold vacuum this weekend, and the video is what I recorded. It's basically steady, but it does move around a little. I'm thinking that this movement is OK for an original 289 that had a valve job 20 years ago. But, I'd like to hear other opinions.
[youtube]WLqyP5SaZbA[/youtube]
Justafordguy
Steady vacuum is a good thing. You just want to adjust the carb for the highest steady vacuum.
wegngis
wegngis
Oregon
I should follow up with the fact that this is pre-adjustment. I was able to get it up to 18+ following the carb adjustment.
But overall, those little bumps and such are considered 'steady?'
pcf_mark
No that little movement is not significant. What type of carb are you running?
pcf_mark
Are you running 12-16 degrees of base ignition timing? That will smooth it out and increase your idle vacuum.
Stick shift or C4?
Where is your vac advance connected to? Ported or manifold vacuum?
(nothing is wrong your engine looks/sounds great I'm just wondering)
wegngis
wegngis
Oregon
Stick shift or C4?
As for the timing, ah, um, uh, I have no idea...there's a paint stripe my father in law put on there back in the 80's. All other marks are long gone. %)
3-speed manual
Ported off the carburetor
Since you don't know where your timing is I would at least try playing with it a little bit. Advance it slightly to see how it runs. If it starts running rough, or makes pinging noises as you accelerate, back it off just slightly until it does not do it anymore.
If you have a stock cam, your vacuum could be up as high as 20 or 21 inches.
An old white mark is very likely close to the stock lines. In your case though, that could be somewhere near 6° BTDC, or even the zero degree mark. Most of my marks are at the zero line, then I work from there. No telling what your father-in-law was used to doing. Might have been stock, or he might have been just like one of us and put that line at an advanced point!;D
Only one way to find out...
If you're ever of a mind to, installing some timing tape from Mr Gasket makes tune-ups and testing a very easy proposition.
wegngis
wegngis
Oregon
You're right (as usual). But I really like that white line! It makes me feel complete and on target, lol. ;D
That Mr. Gasket looks cool, first time I've seen it. I might check it out.
I used it on mine 20 years ago (or more) and have been a huge booster ever since! Since then I've put them on several different engine builds and love how the easy-to-read numbers all through the scale take the guesswork out of things.
Especially when you take into account the potential differences in damper rings that we get these days. You might order a damper for a Bronco, and get the correct part number on the box, but the damper inside might be for an F150 or Mustang and have the markings in completely the wrong place!
Finding TDC once, then installing the tape to match your pointer cures that ill in one swoop.
wegngis
wegngis
Oregon
I'm assuming it's got some awesome sticky on it to keep it from flying off?
pcf_mark
The tapes are awesome! I like to mark my balancer with the tape on there so when it flies off I have 10 - 20 - 30 - 40 on there. Even better is a dial back to zero timing light - no tape or marks required other than TDC. Use a file and put a mark on it then go back and put numbers on with a paint pen.
With a stock cam and a Holley the best I could get was 18-19. For more info drive around in high gear and check you vacuum at various road speeds with a steady throttle.
In my case the sticky was VERY good. In fact, after many years and washings and who-knows-how-many revolutions, it was still on there when I sold the engine.
I cleaned the lip with some Chemtool carb cleaner on a rag before applying, but that's about all the prep I did.
I worried it would only last a short time, but was proved wrong in a big way.
Well worth the 10 bucks or whatever it costs these days.
Of course, all you really need are some good marks that are easy to read with the light, as Mark was saying. But the full graduated printed scale is definitely cool.
