Help needed about shocks
PaulN
I am fairly new to broncos and we have had our 69 bronco for about 3 months now. The bronco is a 302 and has no back tire carrier. It has a 2.5 inch lift with 31s. It has 4 shocks in the rear and 2 shocks up front. Whenever we go over speedbumps or any bumps the front handles fine but as the back tires go over the jolt from the bump is extreme and throws you even when going slow over a mild speedbump. This makes me worried for offroading as that the back will be extremely bumpy. Ive been told that it is because all the weight is infront but is their any way to help minimize the bump in the back. I assume better shocks might help but what else? Is this typical for broncos? Help PLEASE
ENDLIFE
Depending how new you lift is, it can take a looooooong time to break in the rear springs, and it's something a lot of Bronco owners forget to be before they choose to pull leaves. The Bronco is incredibly light in the back, a tip I got from a friend was to load the back of my rig with something heavy, so I put down my tailgate and loaded up a bunch of railroad ties for about a week (it looked ridiculous). However, it did help my rear springs substantially on the trail, it's still a little rough, but better than what I was riding on.
P.S. Get rid of a pair of those rear shocks!
PaveBronco
"P.S. Get rid of a pair of those rear shocks!"
X2 on that. Twice the shocks = twice the resistance to movement, unless they’re specifically valved for a dual set-up, and I suspect in your case they aren’t.
WheelHorse
Paul, post a pic of your current set up and what your idea of off-roading entails? If you plan on running 80-90mph through the AZ dessert, then you will want a premium absorber with a remote reservoir of some kind.
jckkys
If your driving 80-90 in the Arizona desert, you won't be doing very long.
nickgp
First thing i would do is verify that the shocks are actually for a Bronco. Just because they bolt up, doesnt mean they are of the correct valving. Technology has changed, the thought of stiffer is better isnt the way to go anymore. When your shocks as well as springs are properly matched, it should ride correctly as soon as you bolt them on. Sounds like its got too much spring rate and too much compression rate in the shocks. I know youre not going to like this, but you more than likely need to start with new components.
u10072
I would totally agree with nickgp-- the correct springs will whole heartedly ride killer. If you put a WH front coil and rear spring with a good shock you will have a completely different ride.
The reason for the link to GFB and the talk about Bilsteins is that they get lots of good press on here but for what they cost you can get a much better product for the same price. You cant compare a 14mm shaft and a small body to a 7/8 shaft and larger body and expect the same performance. I rode in a wash a week ago in a 2" bodied Fox with 7/8" shaft and it was great-- that ride wouldnt be possible with a basic shock. I realize there are lots have have used the Bilsteins but its been my experience that those who really use the shocks in racing and beating on then for fun dont run the Bilsteins 5100's.
PaulN
PaulN
I have KYB excel-g shocks....the rear is set up for dual shocks in almost a v formation. I'm not sure how old the suspension is...but I assume that the rear leaf shocks are pretty dated I think the front is reasonably new. I would like to do minor trails not going too fast....not serious stuff in any way.
I would like feedback from others. Is it pretty typical for the back of broncos to have a large kick when going over bumps on the back end. Also how good are the KYB excel-g shocks....can someone give me some feedback on what I should do or is it something I should just get used to and not worry about it? Woukd putting a back tire carrier and tire on help or not really
dmwelljr
Sublimity, Oregon
Call raceshocks in Arizona, he sells and builds lots of custom shocks, if you were going to run bilstiens, he would recommend the 7100 series, with custom valveing, but he also has lots of the high dollar stuff to. He's spent a lifetime building shocks for everything from daily drivers to baja trophy trucks. And he gives 10% off for being a member on here.
dmwelljr
Sublimity, Oregon
You might need to update your rear leaf packs, there are a lot of older lead packs out there that ride terrible, especially the ones where someone put a thick add a leaf to gain some heighth
PaulN
PaulN
i do not want to spend a ton of money on shocks....i guess the real question is shocks or new leaf springs?
u10072
x2 how many leafs are in your rear springs. If its like 5 then its a whole problem. Those KYB shocks are a street shock plain and simple. All I am going to say is that I live here in Phoenix and Raceshocks are here in phoenix -- and Im not taking my stuff to them- it would be an emergency before I did that. If I were wanting a really good basic shock then I would use a FOA 2" body shock-- still a bigger shaft and the guy you talk to on the phone Joel is one of the guys doing the building and is a pretty good guy (I've met him actually and he has very fluffy hair and nothing like you would picture in your minds-eye). If you are wanting more get the 2.0/2.5" shock with a reservoir. A set of 2.5" 14" travel shocks from FOA ran me $405 delivered which to me is pretty damn good www.f-o-a.com
blubuckaroo
Grease Monkey
Ridgefield WA
If someone has installed an "Add-A-Leaf" lift to the rear, less shocks won't help the ride much. The added leaf puts the rest of the spring pack into a bind, making it really stiff.
x3 on the pics or a full description Paul. With all the variations on the theme for suspensions, recommendations can be hit-or-miss without the full story.
Not sure how they ride compared to the old Gas-Adjust shocks, but two of those at each corner would have ridden pretty stiff on the rear of a Bronco. The front might not have been so bad, but as the others have said, the lighter rear is more sensitive to that kind of stuff.
And dual shocks in general are better suited for the front anyway. Unless again, as was said, the shocks were specifically valved (or adjustable) for the balance of the vehicle.
I'll agree with the others too, that at the very least, you should immediately remove one shock per corner in the rear. That can be done in a few minutes with basic wrenches without having to jack the truck up.
Take either one, but the factory mount was the rear-facing mount. The secondary one was added to the front. But whichever one is most convenient to get to would be the one I'd experiment with first.
Makes the single shock per wheel scenario even more reasonable.
Yes. It is.
But as you've already read here, MOST of that kick is very possibly from just having dual-shocks in the rear. Maybe the PO (previous owner) carried heavy loads, had duals on the front too, or had some other reason for them.
And also having the wrong shock(s) installed, or old clapped out leaf packs, or add-a-leaves, or some other problem with the leaves and/or bushings and/or hardware could all contribute to your issue.
You mean even more than the previous 15 (actually only 9 by that point) posts?;D
First step is to determine what you have. If you can't post up pictures to a free hosting site online and link them here, maybe e-mail them to one of us (anyone with a "contributor" status below their names) and we can do it for you. Or if you're thinking you might join up for the long-haul, become a contributor yourself (13 bucks I think?) and you can post up images directly without any hassle.
But it's sounding like new shocks would be good.
From my own perspective (working at Wild Horses as I do) a set of Bilstein 5100's would be right up your alley. Or adjustable Rancho RS9000's
At least for us, the prices range from $39 for our WH shocks, to $85 for the Bilstein's, to $99 for the Ranchos.
Any would be a good choice for yours compared to the KYB's I'm thinking, but some of that decision making process will still depend on what springs you have now, or more importantly, what springs you will end up with in the near future.
Yes.
But any time you do one thing, you have to take others into account. Sometimes LOTS of other things.
Start with what's already been said, and see if you are able to improve things first. If not, we'll move on to Plan-B.
Whatever that is! :eek:
Good luck. At least taking a single shock off will give you a quick answer to the basic question. And it's free!
