HELP! removing stock light switch
raleigh_bronco
:mad:<br><br>I've been working on the Centech install all day and was progressing quite nicely until I got to the light switch. How in the heck do you remove that thing from the back side of the dash? And how does the new switch go on?<br><br>FYI, the Centech instructions completely suck. Every step has been a battle. Some detailed instructions would be incredible!<br><br>On a side note, my ignition switch came out after only 5 attempts. ;D
howiebilt
Bronco Buddah
Newton
there is a button on the switch behind the dash that you have to push to remove the knob and shaft . Then you can remove the switch itself . Just feel around and you'll find it ;D
astark
Bronco God
Disconnect the negative battery cable. <br>Remove the headlight switch control knob and shaft by reaching up behind the dash and pressing the knob release button located on the bottom of the switch, it's a little metal post. As you press, pull the knob and arm out from the switch past the two on positions to remove it. <br>Unscrew the chrome mounting bezzel on the outside of the dash by turning counter clockwise, there is a slot in it that will alow you to put a screw driver into and bang on if necessary.<br>The whole switch will pull loose from behind and under the dash. Disconnect the big wire plug assembly from the switch, you may have to pry them apart with a screw driver, if so be gental with it.<br>Now just plug in the new switch and follow these instuctions in reverse.<br>My knob arm was to long, so I had to shim it with a nut between the switch and inside of dash. <br>Good Luck !
astark
Bronco God
Pretty fast there howie(I would rather shove a hornet's nest down my pants and beat it like a bongo)bilt. I am still LMAO from yesterday. <br><br>That was great ;D
raleigh_bronco
raleigh_bronco
So, why in the heck do the guys at centech not tell us this in the instruction manual ?:?<br><br>Thanks Howie and Astark. You guys are great. Congrats to the Razorbacks on their big win over LSU.
howiebilt
Bronco Buddah
Newton
[quote author=astark link=board=5;threadid=11831;start=0#86983 date=1038618821]<br>Pretty fast there howie(I would rather shove a hornet's nest down my pants and beat it like a bongo)bilt. I am still LMAO from yesterday. <br><br>That was great ;D <br>[/quote]<br><br>It's gonna take a while for me to quit laughing about that one too !<br><br>
