So, I ordered a converter today from TCS in Chino, CA. From memory here.....12" HD Converter, 2000 stall, and a custom input inside the torque converter that will lock the smallest splined shaft and the middle shaft together inside the converter, since I have the stock 3 stage input shaft. I was driving when I placed the order so I couldn't focus on wrapping my brain around how this torque converter works, but TCS says it should fit the bill for me. TCS asked about intended usage, HP, tire size, gear ratio
I'm planning to use the Bronco 50% on road, 50% off. Engine should be somewhere in the mid 300hp range, with 33" tires.
Any opinions or experience with this style converter that locks the two smallest input splined shafts together? TIA
