- Nov 12, 2011
- 1,344
You mentioned you tried those stainless retainers with the factory arms as well as the T-rex arms and had the same results... do you have a factory original set of retainers to try for comparison? maybe the stamping of the SS retainers is off somehow?
Whatever you go with just don't expect or plan on attaining perfectly straight springs, it can happen but there are so many variables that can elicit a bow or a twist. Even the suspension cycling is constantly changing the angle of the spring through the radius arm's range of motion.
I ran into some minor issues when putting together my front suspension (Loving the James Duff long arms!), the aftermarket flat style coil cups interfered with my track bar riser and round bump stops. Plus, the springs sat tilted on the flat cups leading to some extra bowing, especially on the passenger side.
I could have made them fit and work but instead I decided to try and make my own, but a little differently.
That all happened here on this page of my build thread... back in the good ole' days;D
I often get asked if my coil cups will cure spring bow issues, I'll tell them it's possible, as it did on my truck, but not guaranteed due to many variables along with differing angles, heights and positions of different suspensions and components.
