Hi All,
I am trying to sort out what in the world the previous owner has jerry rigged here. I don’t think it’s correct... as it just does not fit or work correctly.
The only 2 parts that appear to be correct
By my research so far is the actual kick down rod and the neutral safety switch. The small lever attached to the kick down rod that goes to the trans and the shifter bracket don’t seem right... don’t fit right.
Can anyone shed light on this for me? It’s a Winters shifter with the cable coming from behind the trans. It seems like when the neutral
Safety switch is installed... There isn't much shaft left to mount a shift bracket... let alone the one I have... then it sticks out so far it binds the kick doen bracket unless you leave it intentionally loose.
I would love to upload a photo of what I have going on... but cannot figure out how to do that.
