Help with rear cutouts
BRONC-OH
Wintergreen, Va.
The rear cutouts on my truck are off center to the back tire. P.O. installed some plastic rigid flares and cut as far forward as the body brace behind the doors.
I guess my question is what is the easiest way to fix this? It seems that the cutout only needs to be a few inches forward. Would new flexible flares allow me to open the front of the cutout more? I could sheet metal the rear of the opening (last resort) but if i do that I'm going LUBER.
Advice?
Buster
stock1970
Olathe, Kansas
un attach the flares you have now at the front,on top, and just a little on at the rear where it turns to begin the slant down at the rear.. then see if they can open it up some, I got my flares to open up about 2 inches further forward to make room for 35s, I had to cut a slice of fender out in the front eleminating the body brace.. granted the flare is 1/2 inch short of making all the way to the bottom of the fender at the front but no one will notice..
JGZ
Bronco Hut carries larger size fiberglass flares to solve this problem.Rear flare goes from the rocker panel seam to the corner post seam and they also add a little hieght and width.Mellisa also carries the front set too.If you need pics.Gimmie a pm JGZ
BRONC-OH
BRONC-OH
Wintergreen, Va.
Here is the rear
The cutout is way too far back IMO
Buster
JGZ
Gimmie a e-mail addy and I can send pics. of larger fiberglass flare.JGZ
Scoop
Bronco Old Fart
Cuchara, CO
Those look like Bushwhacker's or Gorilla Warflares. In either case they should stretch forward some (the Warflares more so than the Bushwhackers). I am curious what the other side looks like in relation to the gas cap(s)??
BRONC-OH
BRONC-OH
Wintergreen, Va.
Here ya go
I'm thinking Bushwacker's. these are more of a rigid plastic
BRONC-OH
BRONC-OH
Wintergreen, Va.
Bigger tires are definitely in the plan. Just gotta get all the body work done first. Looks like war flares or some other "larger" opening flare is gunna be the answer.
Buster
