Hey Fathom--Landcruiser Wiper Conversion???
Crush
Greenbottom, WV
Fathom
Was just reading your old post about the conversion, Was wondering if you ever got the78/79 F150/Bronco intermittent wiper setup to work with it?? And wanted to bring this conversion back in the forums.
BronCowie
Old Timer
Vancouver, WA
'not sure what you're asking here, but there is a ford intermittent wiper switch that is nearly a direct replacement, same plug/pin arrangement. The only difference is an additional ground wire you need to land under the dash to make it work and the shaft for the knob is a little longer, needs to be trimmed... it takes about an hour to swap them out.
Crush
Crush
Greenbottom, WV
Fathom (user name) has a thread in the archives about using a 71 lancruiser wiper setup in his bronc. it has one motor and a cable connecting it to the other wiper. he was going to use the untermittant setup you are talking about but never said weather or not he got it to work. i was just wondering if he ever made it work?
