BroncoDon
I am considering a 392 ford racing crate engine. The compression ratio is 9.7:1. Would that be a pump gas motor? What are the guidlines for keeping the ratio under so pump gas can be used (87 or 91).
BroncoDon said:I am considering a 392 ford racing crate engine. The compression ratio is 9.7:1. Would that be a pump gas motor? What are the guidlines for keeping the ratio under so pump gas can be used (87 or 91).
Broncobowsher said:Octane ratings and ion calculation needs a few more pieces of information. Head material and cam choice. Aluminium heads tolerate more compression for a given octane. big lumpy cams tolerate more compression for a given octane. Even little things like quench height affect octane requirements.
I violate several rules and run an 11:1 351 with aluminium heads and a real tight quench on 91 pump gas. That's with an RV cam giving me nearly 200 PSI cranking compression. Wasn't aiming for that much compression when building it, but it just happened.
As for your 9.7:1 you might be able to get away with 87, but probably looking at mid grade 89. you shouldn't need 91 (my guess anyway).
mustangmarty said:It sounds like you have pretty much the same set-up I have but with .5:1 more ion. Does yours ping a lot? If not, how are you keeping it from doing so? Where do you have your timing set?
Broncobowsher said:...Can get minor detonation for a moment with heavy tip in on a well warmed up engine as the vacuum advance returns back to normal....
Broncobowsher said:Doesn't ping. Can get minor detonation for a moment with heavy tip in on a well warmed up engine as the vacuum advance returns back to normal. Timing is set at about 10° base, no idea total. Vacuum advance is adjustable and turned down a lot (had a lot of detonation before I did this).
If it is adjustable (not all of them are) allen wrench down the vacuum port. If you can’t find an adjustment there are distributor recurve kits with the adjustable vacuum advance. That is what I did. Never did put the weight and springs from the kit in mine.mustangmarty said:How do I adjust the vacuum advance down?
