Alright, after doing some more troubleshooting, I fogured out the secondary metering plate was not toght enough. I was using a flat head screwdriver since I didn’t have the right head for the screws, but realized trying not to strip their heads, I wasn’t getting them tight enough.
I got the correct, clutch head bit and was able to get them quite a bit tighter, and then reset the floats, since I suppose, fixing the leak changed created a problem where my floats right now set to high. I was able to tune the idle mixture, screws, idle speed screw, and float settings and the carb is behaving like it should. Idle, accelarator, and everything seems to be a lot smoother.
I’m going to drive it around and see if there is any noticeable imrpovement with the mileage and report back. Thank you to everyone who is able to not only help me diagnose, but also learn a whole lot about my carburetor. Hopefully, I’ll be able to report back some good news!
