Holley Sniper Fuel Delivery Question
377
The Bluegrass State
I’m in the process of getting my motor running on a new build. It’s a 351w with stock heads,stock roller cam, etc. I went through the wizard with no problem. When I crank the engine it shows that it’s syncing then shows rpm but no start. It’s like it’s not getting fuel. So I turn the key to the on position fuel pump kicks on for it’s 2.5 seconds like it supposed to. But I see no fuel be sprayed into TBI throats during the 2.5 second prime. During the snipers prime it should spray a shot of fuel into the tbi throats? I’m thinking the gallon and a half of gas I put in the fuel tank may not being picked up by the pickup? The tank was a bone dry stock type tank. Thanks in advance for any insight or experience anybody can give me.
bronkenn
Bronco Guy
Southeast Ohio
I think you may need to add more fuel to the tank. I left mine loose and ran the gas into a coffee can to make sure I had fuel and also to purge out any contaminants.
Hoses may be backwards. Pump to driver's side inlet.
Regulator on the passenger side goes to the return.
What pump are you running?
377
The Bluegrass State
Boy do I feel beyond stupid!!! The lines are backwards. I'm not sure why I thought the feed was on the passengers side. While I was looking at the tbi I did notice an arc between my brand new MSD coil and its mounting bracket. So now I can fix the lines and move on to replacing my brand new coil!!! The pump is a Walbro pump I don't recall which model number it was though. I bought it awhile back when I was collecting parts for this project. Thanks again for the help.
