TX-ZACH
Fresh off a new new motor build with ATK 351w, roller cam with Edlebrock RPM Aluminum Heads/intake, and Holly 600 Series Carb. Installer suggested a larger carb to fix and said he adjusted it as much as possible. I used the Holly carb off the 302 that was in it prior and everything I am reading says that is plenty of carb. The idle is set a bit higher to help with stall. In higher rpm range it seems fantastic and crisp. Any pointers or suggestions to educate myself would be much appreciated. It still has a 1/2 tank of 3 month old 87 octane fuel that I am trying to use before trying 93 to see if it helps.
Symptoms:
Slight Stumble putting into gear and from idle to 1/4 throttle: Feathering the throttle and slight higher rpm clears it upon take off
Exhaust smells super rich from unspent fuel
Symptoms:
