Homemade tank
Rymadd
Hey guys, looking at building an oversize tank. I know alot of you think that it isn't worth it, dangerous, blah,blah,blah, but I have more time then money so it's worth it Plus I have shears and breaks at my disposal. Anyways I have built tanks for a couple of things before never a car however. My question is Should I pay the extra dough for stainless or use regular steel and coat it in something. I have a mig, and no spool gun so aluminum is out of the question. Some say steel won't rust if it has gas in it, but I built a gas tank for a wakeboard winch and left it over winter half full and it started rusting.
Any advice on sending unit/ in tank pump is good too. I just read a thread about somebody looking for a gauge for the explorer unit. Is that a good place to start? I have multiple you pull it yards at my disposal.
br0nc0xrapt0r
Loves pickles
Eastwood tank sealer and if you read further most are using exploser sending units with built in pumps.
Rymadd
Rymadd
I have read about homemade tanks for other vehicles and most people say to put a sump in the bottom for when you are on your side with low fuel. Nobody did that on any of the ones I saw, is this because they are already hanging down low when making a 20+ gallon tank? Or does having the baffles help with that, since you probably shouldn't be out in the woods wheeling with only a couple gallons in the tank?
br0nc0xrapt0r
Loves pickles
Not really sure. It's kinda a non issue to me because I use external pumps since I can get low and high pressure external pumps at anu auto parts store.
Rymadd
Rymadd
Assuming you changed your sending unit what did you do about your fuel gauge then?
br0nc0xrapt0r
Loves pickles
I have not made the tank yet, only laying plans to do so after Howiepalooza, however when I do I plan to use a stock sending unit and cut/extend/bend to allow for full tavel of the range of fule level in the new hi cap tank. This should allow for the stock setup to funtion as intened although that gauge hasn't worked since I bought the damn thing anyway.
WorkerBee
Northern CA
Wow I did a search on here and didn't see this thread, surprising because it is so recent also. Thanks!
not very much info on sending units/pumps in it though.
And do people still seal when using stainless? I have just filled with water and pressurized, marked the holes, then reweld there until there is no leaks
I did not use a sealer with mine. I dye tested all the welds. The only place I had small pin holes were where I MIG welded the retainer on top and the filler bung. None of the TIG welds leaked.
I didn't use any special dams or anything for the pump in the tank. I have baffles but that's to help eliminate sloshing. With in tank pumps you should really keep a fair amount in there to keep the pump cool. If I run out of fuel on an incline that's my own fault because at that point I'd only have a few gallons anyway.
jim3326
Appleturkey
Since you only have a mig I would use paint-lok then coat it after you test for leaks. That way there isn't as much worry about rust. If you have a tig available, use SS, it's also a little tougher to penetrate with a rock.
Jim W.
stupidboy
My wifes porn star.
Morrisdale Pa.
Look through my build thread, I built a tank using a explorer pump and DID put a sump in it. The pics are in the thread starting on page 35 post #516. Would also add that the tank is worth the money to buy after all said and done. You will not save any money in the long run, I even mentioned that in my thread.
