Hood Pins pictures
Skiddy
Since I am redoing my hood, I need new hood pins. the old ones were just cheapies that the scuff plate was about like tin foil lol. I see summit has some with the twist type lock, not sure if I would trust them or not. so what are you all using
Monster Mike
SteveL
Huge chevy guy
Hawthorne ca
I had the cheap locking pins on the 66 for a while. They were a pita. Occasionally the vibration would unlock em. Another thing if they started to unlock you cant get the key in to lock or unlock em. With the locks it was always on my mind what if there's an engine fire or other emergency under the hood. Now I just run standard pins. I have the nice urethane ones wh sells on the shelf.
ENDLIFE
These are probably my all-time favorite, as my kids had a habit of dematerializing my cotter pins. I'll post some pictures later on.
Scoop
Have Bronco, Will Travel
Cuchara, CO
X2. I have these on my 78 Bronco - minus the locking feature. They work great and look awesome. Only issue is they are a bit harder to install because of the odd shaped hole you need to cut. But well worth the extra effort.
pbwcr
Autofab hood pins like most prerunners and desert rigs use. Made my own tethers
Hood top
Underside showing hood and pin on the core support
PaulW
pbwcr
Yup they come in colors. My pic missed the detail that is no bracket is required. The pin bolts directly to the core.
nvrstuk
You'll be much happier if you get in the habit of putting the clips OVER the pins when the hood is raised so it will be VERY hard for you to not notice that the hood isn't all the way down.
There are too many stories of hoods blowing up and co$ting ya...
ntsqd
heratic car camper
Upper SoKA
^^^^ Wot he said......
I put the clips back into the holes in the pins as I'm raising the hood.
nvrstuk
It's the HABIT...gotta do it EVERY time....
so far, so good...
