Hood support using hydraulic props
WPS 73 Bronco
The Woodlands, Tx
I've got Tom's hydraulic hood props on my Bronco. I just noticed that one side of the hood has a small crease and it's allowing the hood to buckle when closing. What have others done to add support to the hood to prevent further damage? I went on their site and I don't see any pre-fab'd support brackets.
Yeller
Rogers County Oklahoma
Every bronco hood does that eventually, in my experience anyway, without the hydraulic prop system, the system just exposes the week link immediately. As stated by @jeffncs add some angle iron along the length of the hood, preferably all the way to the leading edge. I've never had one not crack over time, especially since we are now driving these machines faster than ever before, the air pressure is intense.
PCB 4x4
I bond a piece of 1/2 square tubing to the underside of all our hoods.
bigmuddy
Marthasville Missouri
When I bought hood struts, I settled on Duffs, because they had the support across both cross braces and the strut anchor points on the hood were farther from the hinges.
Same. I had a set from BC years ago for a fiberglass hood and they were bonded to the hood with a supplied epoxy. Worked great.
PCB 4x4
I'm pretty sure 1 inch is to big to fit inside the channel
