THIS IS AN EARLY '66 BRONCO U13 170 CID
I THINK I'M MISSING SOMETHING IN MY HORN BUTTON AND I'M NOT SURE WHAT IT IS AS THE SHOP MANUALS DON'T SHOW MUCH SO I'M HOPING SOMEONE HERE CAN HELP.
THIS A A PICTURE OF INSIDE THE HUB AT THE TURN SIGNAL SWITCH AND HORN CONNECTIONS. THE HORN SOUNDS WHEN THE TWO BUTTONS AT THE YELLOW ARROWS ARE CONNECTED:
THIS IS THE PLATE ON THE BOTTOM OF THE STEERING WHEEL WHICH GOES ON NEXT AND THE COPPER IS WORN THROUGH IN THE MIDDLE AS YOU CAN SEE. IT SEEMS THERE SHOULD BE SOMETHING ELSE IN HERE BETWEEN THE STEERING WHEEL AND THE HORN CONNECTIONS:
THIS SHOWS THE UNDERSIDE OF THE HORN BUTTON AND THE TAB AT THE YELLOW ARROW MAKES CONTACT WITH THE YELLOW ARROW IN THE NEXT PICTURE:
THIS IS THE TOP SIDE OF THE STEERING WHEEL:
WHEN ASSEMBLED, PUSHING THE HORN BUTTON DOES NOTHING, THERE IS NOTHING HERE TO CONNECT THE TWO HORN CONNECTIONS WHEN PUSHING THE BUTTON.
DOES ANYONE KNOW WHAT IS MISSING AND IF THE PART IS AVAILABLE?
THANKS A LOT FOR YOUR TIME!
dOES ANYONE KNOW WHAT IS MISSING
![Dsc07578m.jpg](http://www.tbirdsquare.com/Bronco/Dsc07578m.jpg)
![Dsc07579m.jpg](http://www.tbirdsquare.com/Bronco/Dsc07579m.jpg)
![Dsc07580m.jpg](http://www.tbirdsquare.com/Bronco/Dsc07580m.jpg)
![Dsc07581m.jpg](http://www.tbirdsquare.com/Bronco/Dsc07581m.jpg)
