eds66bronco
trying to get the horn setup and ran into a snag. i did a search and that helped a little. i have power and when i ground the spring loaded contact button to the outer column the horn works but not by grounding to the steering shaft. so here are a few questions. i have a 77 harness and auto steering column with single horn just to clarify-
1) does the horn relay body need to be grounded to work correctly? mine is just hanging loose-not bolted to body yet.
2) is there supposed to be one or two spring loaded contacts in a 77 coulumn? mine only had one and the steering wheel side only has one ring to make contact with it. where should it be getting ground?
3) should i have 12v constant at the that contact button while grounding to the steering shaft? i do but if i connect a wire to the same spots, the horn will not honk.
li'll help please
li'll help please
