casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I have a new junkyard steering wheel in my 74 and I really like it. Its a leather wrapped unit from a late 80's F250. Anyway, this wheel uses a two contact setup for the horn and my column is set up for a single contact wheel that grounds through the steering shaft ( I think ). So my solution was to find a turn signal / horn switch that had the two contact setup. I found one that looked like new in another truck and put it it in my column this evening. Because it has two contacts, it has one more wire than my old one. So, I'm thinking all I have to do to make the horn work will be to ground the extra wire. It seems pretty straight forward but I thought I would ask before i accidently start an electrical fire.
