When horn works directional signals don't
K
keymonkey
Newbie
Issues with shift tube, collar and levers.
And prior to that not being able to get the horn to work correctly.
I gave up on that and ran the wires to the washer pump switch on the dash.
Can't seem to get the pin puller in. Does that red plastic part of the socket need to be removed? The sockets flair at the end so the plastic tube where the female pin slides in is the same size as the tube on the puller.
Jonathan_Cole
Newbie
Can't help you there. I just realized 74 is different from 66-73.
K
keymonkey
Newbie
No..problem could not get the wires down the column with the metal pins on them anyway....cheated and cut them off, soldered them to the existing and pulled them through one by one. Just going to solder them to the existing plug and call it done.
