how far off can gearing be between front/rear
Kyle.malone
Norman, OK
Looking at some of the gearing and possibly doing a currie high 9. How far apart is ok for the gearing to be. For example. If I go with the currie 5.29 (only ratio they have above 4.86) What would I use in my Dana 44 front (5.38) or is that too far apart? If it is, I am going to go with a standard low pinion third.
You may want to rethink the Currie high pinion (8.8" IFS front ring and pinion set from and F150) that has a custom casting for the 9". I talked with Currie a few years back and they did not recomend their high pinion conversion for tall tires, heavy vehicles or high HP levels. You have all 3 things Currie stated not to use.
As far as how far off the ratios can be? There are a handful of guidelines. There is no black/white line that is good/bad. Just shades of gray. 3.50 and 3.54 are fine. In mud I have heard of running a taller ratio in the front so it pulls a little more to help keep it in a straight line. Then you get some who get paranoid with 4.09 and 4.11. Think of the difference in tire travel distance when making a turn? Makes matching ratios kinda pointless due to the tire scrub. 5.29 and 5.38 is a little bit of a spread, but isn't really that far off then the factory 3.50 and 3.54 when you actually figure the percentages.
PlaneDrvr99
Norman, Oklahoma
I am no authoritative figure on this, but a long time ago, I was told that the front and rear diffs could not have more than 1% difference in ratio.
Now like I said I am not sure if that is true or what not, thats just what I was always told.
markperry
I would go with Tom's custom dropin for about 3 or 400 dollar difference......just my 2 cents
gotdads68
I'm running 5.29s rear and 5.38s front in one of my rigs, no problems. ;D
KyleQ
Why do you want gears that deep with a 4R70W and an Atlas 4 speed?
I've got a NP435/Atlas2 3.8:1, 4.11's and 37's and 1st gear is 105:1 - very low. Now I don't have lots of rocks to crawl over around here, but it's so damn slow it's almost worthless.
If you went with the 4.86 gearing your first gear crawl ratio would be 143:1, less than 1 foot per second and idle speed... But hey, maybe that's what you want.
I would stay away from the Currie Hi-8.8 - Checkout these guys, they are within the same price range. http://www.truehi9.com
Needs the low gears to use the overdrive (that you don't have). The crawl ratio being super low is just a side benifit.
Pa PITT
Stephenville TEXAS
.. I'll ask what terrain are you playing in.. I've heard for years if your fronts are like 5:38 then your rears can be 4:86 if your surface is like mud or sand. Keeps your front pulling you forward.
... On solid surface, gravel, mine doesn't even like the 3:54 rear and 3:55 fronts ..
Kyle.malone
Kyle.malone
Norman, OK
I went with the 5.14 in the rear (*Richmond Gears) and and going to be putting a 5.13 in the front (haven't decided on the manufacturer yet) and a Eaton Electric front locker. Currie told me that they do not recommend their high 9 (8.8 reverse cut gears) in a rear application and definatly nothing around 400 HP. I was told they were meant for front applications that are putting in a 9" front. But it still won't handle the HP. I ended up going with a new 3.250 case since I am going to go with 35 spline rear axles. Should have the rear end put together by the end of next weekend.
