ca1a73 said:POR-15 on frame, so in the tub should be ok?? Looks like the PO of my bronco did the frame axles in POr, I guess im lucky.
That's a good plan. Prep correctly though!ca1a73 said:My plan is to POR- over the existing por(some cracking and chips.) the herculine over the POR. carpet the front cab only, leave the back .
HotWheels said:one pint is more than sufficient. I did mine with a brush and it looks like it was sprayed.
Mark Troy said:That's a good plan. Prep correctly though!
Sandblasting is Ideal!Baja71 said:How do you prep the frame before applying?
PeteO said:im starting with a rusted frame. should i wire brush the thing first? sand blast it? i thought i read somewhere that POR clings to scaley rust best.
I always used their Metal ReadyCrazyHorse72 said:Just use a wire-wheel to get the scales and loose stuff off. It needs rust to bond properly. Otherwise you have to use a metal prep so it will stick.
