crutch
- Jul 3, 2015
- 249
I'm running Holley Sniper EFI on a 347 stroker with Edelbrock intake manifold and currently have my PCV valve hooked up from passenger side valve cover to the vacuum source on Sniper. The other valve cover with oil filter neck I have a filtered Air breather cap. I was doing research and sounds like I'm introducing unmetered air into the system with this breather cap. I've read a bunch of the forums and unclear how to hook up this other valve cover oil filter neck. I've seen some mentions of using a cap but doesn't the system need a source of clean air to pull through the crankcase? I've seen other mentions of needing a vented cap that gets clean air from after the MAF but where is that connection?
Can anyone provide clarity on this and a recommendation? Thanks!
