hydraulic clutch Help
colelyle
Calgary Alberta
hey guys
need some help with my hydraulic clutch conversion
i saw the tech article by Cory Walden and decided to do it
every thing has worked great so far
i bought the wilwood large volume master cylinder 3/4 bore and the salve cylinder
i have everything hooked up
problem is, is that the pedal is really stiff
should it be????
thanks
cole
Desert Thrasher
Thanks for enjoying my article. With the 3/4 bore the pedal will be stiff, but usable. I used that master cylinder because I liked the way it looks better than their smaller one. However I did eventually switch to the smaller 5/8 bore and it was noticeably different. Hope everything works out for you.
