Hydraulic clutch help
66 Bronco Dave
Doing M5od swap. Anyone have pics of master and brake booster at firewall. I’ve looked at various threads and can’t find a pic of this condition. Don’t have my booster yet just starting the mock up. Thanks.
66 Bronco Dave
1.5 inches. You don't have to do it the way I did. You can fab up something for the top of the peddle to limit the travel. I just did it the easiest way I could think of.
Tim
Thanks. Gonna try the modern driveline system to get full clutch pedal travel. Just order brake booster Gonna wait till it arrives to mock everything up. Their system looks like it might work.
66 Bronco Dave
Tim
Couple pics here
https://classicbroncos.com/forums/threads/m5odr2-conversion-complete.314563/
If that's not what you need I can snap a few others
Tim
do you have a pic of your crossmember trans support
Timmy390
Conway, AR
I do.....These pics are of it just tacked together. I fully welded it and put caps on the tubes. Then primer and paint. I can't find a pic of the "finished" product but I didn't change anything from what you see in the pics.
Tim
66 Bronco Dave
Tim
Thanks Tim I made mine today. Did a mock-up with wood then went for it. Just need drill and make side mount plates. Think I’ll start a build thread.
