Hydro Boost Hoses
broncojack
I'm doing a Hydro Boost install on my Bronco that has the Saginaw pump v belt and 4x4x2 power steering box on it. Has anyone found pressure hoses that fit this combo or will I have to get custom made hoses made?
Thanks Jack
tasker
all knowing of nothing
NH
I had mine made Jack....local hydraulic house....was pretty cheap as I remember as well
toddz69
Make your own, Jack! Lots of fun to make them and you can clock the fittings so they're just right, the hoses are the right length for clean routing, etc. Use -6 AN adapters on everything and you'll have a nice system. Use black or blue fabric-covered p/s hose to match the underhood aesthetics on your truck.
Todd Z.
sanndmann3
radiator shop made mine up...
shouldn't be too to get made.
I didn't consider the AN option back then. Worth checking out...
broncojack
broncojack
I ended up using a hose kit at Summit form Trail Gear.
The system works great, should have done it years ago!
Thanks guys.
