motoman
Ok.......
lengthened the rod to 5" to center of the "O" end.....
*Got all the lines hooked up
*Got the new brake lines from proportioning valve to MC
*Bench bled MC
*Hooked up brake lines to MC
*Filled PS Pump and bled PS system
*with engine off bled brakes (64 OZ of brake fluid) pedal still goes to the floor
*started truck and truck steers ok but when the brakes were applied the lines jump and sound like HB goes into bypass
*realized HB lines were backwards (F$%K!)
*Re-made lines, reconnected, filled and bleed PS system
*Pedal still goes to the floor
I carefully vacuum bled and 2 man bled all the brakes till i see NO air coming out of the bleeders..... why is the pedal still going to the floor?
HB 1997 F250 Diesel (junkyard)
MC 1985 Dodge Diplomat (new)
AGR Pump \ 1974 Mark IV dual return reservoir
Could the HB be bad and allow the pedal to the floor?
Is the MC bad?
ARRRRRRG! Thanks in advance!
*Bench bled MC
Is the MC bad?
