Hydroboost upgrade went haywire (brake gurus please help)
Rox Crusher
Rox Crusher
Well I finally found the culprit........
After trying new master cylinders (both Astro and camaro) they still weren't working
Replaced the prop valve from the junkyard with another prop valve from the junkyard and now I have a broken nose and need a new windsheild
70_Steve
Old Guy
Glad you found the problem. Confirmation sucks a bit, though...
Is the doctor on the way to the glass shop?
Rox Crusher
Rox Crusher
UPDATE:
I never could get my brakes back to where they were functioning like they used to but I had gotten used to driving it with less than perfect brakes.
Tonight I relocated the reservoir using an idea that 76Fordbronco @ ACB had about making a bracket that mounted on the little tab on the front of the upper intake.
This allows the discharge port on the reservoir to be slightly higher than the intake port on the power steering pump. The hose barely has any downward angle to it but it is much better. When I had the reservoir mounted on the fender it had a pretty significant slant from the pump down to the reservoir which I had heard was ok so long as the fluid level was higher than the intake port on the pump.
Well, I took it for a test drive and while they still aren't 100 perfect they are way better and the brake imbalance light finally went off. I think with a little more driving to get the air out of the system and a couple more rounds of bleeding the brakes I won't have to worry about them anymore
Viperwolf1
electron whisperer
Progress?!! He's been in all out upgrade mode since getting that bigger MAF meter. I think he's afraid the Junk Yard Dog will be faster than his Bronco.
Rox Crusher
Rox Crusher
UPDATE:
ANOTHER UPDATE:
If you really want to dislodge air bubbles out of your brake lines and components, take your Bronco to Moab and bounce it around on the rocks and washboard roads.
They are working great now and I think it is because there was air trapped in prop valve.
