latrucker, why are your hard lines routed so far away from one another? If they're both going to a common distribution block, such as a common proportioning/combination valve like in the diagram, or even an older H-block, they sure go a circuitous route.
Looks from here like the front reservoir feeds directly to the rear brakes and the rear reservoir feeds directly to the front brakes. But you say you have a combo valve somewhere? Or are you running just the manually adjustable prop valve?
Also, those nicely done coils in the rear line are vertically wound, rather than horizontally like you see all (or at least most?) factory hard lines. This coil orientation might be capable of capturing air, even though in theory there's enough fluid pressure during brake bleeding to push all the air past the coils. One would think anyway, but it's a possible point of discussion.
Any chance you have a recent leak in the system with all the other work going on? Maybe some air is getting into the lines as you bleed.
Good luck.
