mynameisjonas
- Dec 1, 2016
- 9
I am looking for some help to diagnose a soft brake pedal and mediocre brakes after I replaced all of the brake lines and master cylinder. The Bronco has 4-wheel disc brakes, and it had the HydroBoost brake system already installed, and it was wokring. fine The brake lines and hoses were corroded and in real bad shape from sitting outside at the beach, so I replaced them, along with the brake master cylinder. I have bled the system several times and confirmed there are no leaks and no air, but the brake pedal is soft and although the brakes work, they don't work very well, and nowhere how they did before I replaced the parts. I am leaning towards the new master cylinder, as I look at the specs for other complete kits include a 1 - 1/8 inch/ bore master cylinder, and I know mine is 1". I could not find a part number on the old one, so I just relied on the local NAPA to match it up. I suspect the old one could have been a 1 - 1/8 inch bore. Would the difference of the master cylinder bore be what is causing this problem?
