OK, so I thought I had everything for my hydroboost swap...hose kit from Hydratech, 2003 Mustang Mach 1 hydroboost/MC.....assorted odds-n-ends.
I have been tinkering with the stuff in my pole bldg. off and on. Today I went to remove the low pressure return nipple from the hydroboost....what a bear to do. Now, I think I screwed up royally....it seems to have a tapered thread that NAPA couldn't find and the local hardware couldn't match either. Next stop was a Ford dealer....STICKER SHOCK...$149!!!!! just for the straight/screw in nipple!!!!! It's no longer made, either. That is more than I paid for the entire hydro set up (inc. MC, hoses, prop. valve, etc.).
My question after all this is: can I JB weld the nipple into the HB??? Or, should I use a tap and re-thread the hole and get a new fitting???
I wanted a 90 degree fitting to begin with (that is why I tried to take the straight nipple out).
Since it is the low pressure line, I was hoping the JB weld would work vs. re-tapping and forgetting the 90 degree fitting.
What should I do???? Buy another hydro??? or one of the above options??
Any input is welcome....thanks in advance!!!
Pops
Pops
