Rox Crusher
- Dec 13, 2008
- 2,773
so back in 2010 I upgraded my 77 to hydroboost using the following components;
- astrovan booster, camaro master cylinder, saginaw dual return pump, stock power steering gear box, and h-block. When I put this system in it worked way better than I expected and was working flawlessly before I started my swap.
- I recently completed my 5.0 Explorer swap which means I now have a brand new Explorer pump, a single return remote reservoir, and I swapped out the camaro master cylinder for a new astrovan master cylinder with S10 reservoir
when I went to bleed the brake system I noticed that the h-block was leaking at the imbalance switch so I went and got one from the junk yard and it no longer leaks.
now to the problem, the rear brakes are working well but the front brakes don't seem to be working at all.
I ca't get the pedal to firm up even though I have bled the system several times. There is still a minute amount of small air bubbles coming from the front calipers but I'm not convinced that is the whole problem.
please send me in a direction that allows me to get this sucka back on the road
thanks in advance
thanks in advance
