G
Guest
Guest
Okay, I'm going 4 wheel disc from manual drums in one shot, and since my plenum on the EFI is so close to the drum master cylinder, I'm going to have to relocate it somehow. Here are my choices:<br>1) OEM style vacuum booster/ bracket setup. $400??<br>2) different intake manifold, explorer 5.0 setup? not sure if I can use the explorer intake with the stock 5.0 HO heads.. and use the disc mc as a manual setup.<br>3) hydroboost- I found a set of 79 Caddy calipers, booster/mc, pump, hoses for $130. should i jump on it??<br>ANy input is appreciated. Thanks guys..<br>
