TOFIC
Bronco Wrencher and Fixer
Coob said:Has anyone successfully used a Hboost system with an internal canister? Curious because it seems like it would take less room once mounted.
I found one the other day at the junk yard off a mid 80's oldsmobile. I went ahead and bought it but not sure it would work. I does have the internal canister but the mate up to the master cylinder is a bit off. I may have to pull that from the old's as well.
It will work but I would be a little uncomfortable with it. No-one has said anything about it to me or others. Let us know how it goes.
Definitely use the Olds MC. the alignment of the actuating rods is critical in the system as the proper alignment ensures you have a braking system when the boost fails. Please don't mickey mouse around with this, I like talking to you not talking about you if you have an accident if your systems fails at the wrong time. Not trying to be alarmist, just real cautious. My first system was tested 6 ways to hell before I drove it. Please do yours this way.
TOFIC
