Front outside brake lines r & l side new not SS $20
rear hatch plate cover for hard top $3
door cups $3 pair
door handles $3 pair
jack hold down strap $4
rear tailight bezels look like spun al. not chrome $15
28 spline axles bb 9" ask which side if your interested $15
(2) Dana 20 transfer cases J shift $40 each
(2) 3spd trannys 6cyl $30 each
Automatic flywheel sb ford $15
pair of stock rear leaf springs \no shackles $10
manual flywheel 6cyl $10
Bellhousing 351w $35 /// $95 used @ toms bronco
Headlight rings painted 2 pair $5 pair
ash tray $5
driveshat front no cv joint $20
Wiper motor cover with light painted black $15
mirror windshield factory $10
wiper fluid box $10
hood props $5 each
J-shifter--$10
knob-$3
3 on the tree 3spd linkages $10
6-cylinder throttle cable and bracket $10
Gas pedal $10
dash pad has a few bad spots might need cover $10
clutch parts; fork $10
pivot lever or swing arm? $10
seat belt $10 each sold pair have 3 one side only w. release and adj and one other side
hood spring $5
hood release and lock bracket $8 each have two
locking hub internal parts --ask
rear brake drums 10" off road only can't be turned any more but they will work $10 pair
1 front brake drum $5
off road drum hubs $10 pair
original steering wheel cracked but usable 74 $10
aux tank skid plate only $ 10
factory distributor sb ford $10
wiper motor bracket $10
2bbl carb 1.08 venturi motorcraft 2100 $20
many small items ask and I'll look
Send private message please
Looking for vent windows and windshield
do you have the 6cyl 3-speed/dana20 adapter?
lets netgotiateFront outside brake lines r & l side new not SS $20
door cups $3 pair
Bellhousing 351w $35 check on it-- $95 used @ toms bronco
ash tray $5
wiper fluid box $10
hood props $5 each
J-shifter--$10
knob-$3
Gas pedal $10
hood spring $5
lets negotiate
Front outside brake lines r & l side brand new not SS , never used $20
door cups $3 pair
rear tailight bezels look like spun aluminum not chrome no bends $15
(2) 3spd trannys ran $30 each
Bellhousing sb ford $35 check on it-- $95 used @ toms bronco
Headlight rings painted $5 pair
ash tray $5
driveshaft front no cv joint $20
wiper fluid box $10
hood props $5 each
J-shifter--$15
knob-$3
Gas pedal $10
dash pad has a few bad spots might need cover $15
hood spring $5
hood release and lock bracket $8 each have 3
door cups $3 pair
28 spline axles bb 9" ask which side if your interested $10
(2) Dana 20 transfer cases J shift $25each
(2) 3spd trannys ran $20 each
Bellhousing sb ford $25
ash tray $5
driveshaft front no cv joint $10
Wiper motor cover with light painted black $10
mirror windshield factory $5
wiper fluid box $5
hood props $5 each
J-shifter--$10
knob-$3
6-cylinder throttle cable and bracket $5
Gas pedal $5
hood spring $5
Rocker panel repair 3 sided $20
door cups $3 pair
ash tray $5
wiper fluid box $5
hood props $5 each
J-shifter--$10
knob-$3
Gas pedal $5
hood spring $5
door cups $3 pair
ash tray $5
wiper fluid box $5
hood props $5 each
J-shifter--$10
knob-$3
Gas pedal $5
hood spring $5
that is it !!!!!!!!!!!
