Pm sent............
I lied have to keep selling
Pm sent............
Front outside brake lines r & l side brand new not SS , never used $20
rear hatch plate cover for hard top $3
door cups $3 pair
door handles $3 pair
jack hold down strap $4
rear tailight bezels look like spun aluminum not chrome $15
28 spline axles bb 9" ask which side if your interested $10
(2) Dana 20 transfer cases J shift $35 each
(2) 3spd trannys ran $20 each
pair of stock rear leaf springs \no shackles free
manual flywheel 6cyl $10
Bellhousing sb ford $25
Headlight rings painted $5 pair
ash tray $5
driveshaft front no cv joint $10
Wiper motor cover with light painted black $15
mirror windshield factory $5
wiper fluid box $5
hood props $5 each
3 on the tree 3spd linkages $10
6-cylinder throttle cable and bracket $5
Gas pedal $5
dash pad has a few bad spots might need cover $15
clutch parts; fork $10
pivot lever or swing arm? $10
hood spring $5
hood release and lock bracket $8 each have 3
locking hub internal parts --ask
rear brake drums 10" off road only can't be turned any more but they will work $10 pair
1 front brake drum $5
off road drum hubs $10 pair
original steering wheel cracked but usable 74 $10
aux tank skid plate only $ 10
factory distributor sb ford $10
wiper motor bracket $10
2bbl carb 1.08 venturi motorcraft 2100 $20
many small items ask and I'll look
Send private message please
Front outside brake lines r & l side brand new not ( SS ) never used $20
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
look no brakes
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
I cant stop selling partsFront outside brake lines r & l side brand new not ( SS ) never used $20
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
please buy partsFront outside brake lines r & l side brand new not ( SS ) never used $20
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
Front outside(drum) brake lines r & l side brand new not ( SS ) never used $20
rear tailight bezels look like spun aluminum not chrome no dents $15
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
Wiper motor and bracket $20
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
Misc u- bolts $10 set of our
Rocker panel repair 3 sided used no dents $20
Can you tell me what shape the driveshafts are in?
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
bump to the top
bump,bump
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
