cekautsky
Question#1:
Would you expect to see a measurable drop in water temp by installing a remote trans cooler? I`m thinking about going with a remote trans cooler because my water temp runs 180 to 200 around town and easy offroading. Temps shoots up quick to 220+ on extended uphill runs. Current trans cooler is in the Ron Davis (RD) aluminum radiator with 17inch pusher fan, flowkooler water pump, and a 180degree stat.
Question#2:
Is a Heavy duty copper/brass radiator better for cooling? I am tossing the idea around of going back to a heavy duty copper/brass radiator. I have heard others suggest that water flows too fast through the RD aluminum radiators for best cooling. Im not 100% convinced about this theory but it is something that i am thinking about. My goal is to build a bullet proof cooling system for my 1974 with stock 302 & c4 so that i can run the 100+ degree AZ desert.
Before i just start throwing money at it i thought i would see what you guys have done to address cooling issues. Any advice would be greatly appreciated...
Thanks in advance for your input.
Question#2:
