broncoitis
- Jul 23, 2010
- 4,449
Well, the conversion to the EFI is done and I have finally driven the truck after it being a work in progress for 10 years. Good Times for sure! ![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
However, some little problems have shown their ugly heads and the most important at this point is the alternator. I think it is going bad. The drive started out well for the most part. Other than being cautious and needing an alignment the truck ran OK. However, about halfway through the ride I noticed that the voltmeter gauge was starting to go down! Instead of showing 14 Volts like it should it was showing less than 11 Volts. Not a good thing at all!
Being that my Dad was following just to be sure that nothing happened he went and got some jumpers while I waited. Looked things over while waiting but all seemed OK for the most part. When he got back, he jumped me and the Bronco fired right back up and again the Alternator seemed to be charging the battery because I could see the Volts go up with increased RPM! Thought all was well but once again the Volts began to drop when all the lights were turned on. Would come back up a bit with the headlights off but drop immediately when I turned them back on! %)
Of all the things that have been replaced for the conversion to the EFI and Explorer Serp the alternator is the only major component that has not been replaced and I have no idea how old it is unfortunately. I think it needs to be replaced!
Any other thoughts?????
