And from your stated intended use, don't waste too much of your time hunting for a Dana 44, as your 30 will be perfectly happy with your combo.
The only reason you might "need" the uprated 44 is if you do start to hunt out larger tires, or go hard wheeling, or get yourself into a little too much fun in the dunes.
That last might be the only real reason to upgrade. But frankly, even with the 30 in the dunes, if you install some kind of a truss you can get away with a lot of abuse before it starts complaining.
The lower gearing hurts too of course. As the numbers get larger (lower ratios) the pinions get weaker. Same for a 44 too, but it can take a little more abuse at the higher numbers.
Sounds like you'll be fine for now. Can you post up what your current gear ratios are? Maybe based on your VIN or better yet if you still have a Data Tag on your driver's inside kick panel, or even better still, the axle tags still attached under a bolt head on the front cover and rear center section.
Have fun!
